How to set the parameter for clock tree such as insert delay and skew in SoC ?
lightcloud
Member level 4
Member level 4
In soc encounter,how to set the parameter about clock tree such as
insert delay and skew? I cannot find the menu.
thanks a lot
soc encounter
Refer to encounter user guide, there is a chapter of synthesizing clock trees. And I do recommend you write a Clock Tree Specification File to fully control it. GUI is not so recommended.
Reactions: ivlsi
    ivlsi
cts file for encounter
SDC from front-end sythesis tools can be used to constrain the Clock tree. it also the front-end designer want the clock tree should be.
soc encounter cts
Everyone use the *.cts file. Refer to the chapter "Synthesizing clock Trees" in the Encounter user guide(soceUG.pdf). You can use "specifyClockTree -template" command to output a template.
Regards,
Eng Han
www.eda-utiliteis.com
