#include "driverlib.h"
uint32_t fq_SMCLK = 0;
uint32_t ucsFault;
void setConf(void);
void clockConfiguration(void);
int main(void) {
WDT_A_hold(WDT_A_BASE);
P1DIR |= BIT0;
P1OUT &= ~BIT0;
clockConfiguration();
setConf();
fq_SMCLK = UCS_getSMCLK();
while(1);
void setConf(void)
Timer_A_initUpModeParam upMode =
//uint16_t clockSource;
TIMER_A_CLOCKSOURCE_SMCLK,
//uint16_t clockSourceDivider;
TIMER_A_CLOCKSOURCE_DIVIDER_64,
//uint16_t timerPeriod;
((4000000/16/64)/120),
//uint16_t timerInterruptEnable_TAIE;
TIMER_A_TAIE_INTERRUPT_ENABLE,
//uint16_t captureCompareInterruptEnable_CCR0_CCIE;
TIMER_A_CCIE_CCR0_INTERRUPT_ENABLE,
//uint16_t timerClear;
//TIMER_A_DO_CLEAR,
TIMER_A_SKIP_CLEAR,
//bool startTimer;
Timer_A_initCompareModeParam comp =
//uint16_t compareRegister;
TIMER_A_CAPTURECOMPARE_REGISTER_1,
//uint16_t compareInterruptEnable;
TIMER_A_CAPTURECOMPARE_INTERRUPT_ENABLE,
//uint16_t compareOutputMode;
TIMER_A_OUTPUTMODE_TOGGLE_RESET,
//uint16_t compareValue;
((4000000/16/64)/120)*4/5
Timer_A_initUpMode(0x0340, &upMode);
Timer_A_initCompareMode(0x0340, &comp);
Timer_A_enableCaptureCompareInterrupt(0x0340, TIMER_A_CAPTURECOMPARE_REGISTER_1);
Timer_A_enableInterrupt(0x0340);
Timer_A_startCounter(0x0340, TIMER_A_UP_MODE);
P5SEL |= BIT2+BIT3; // Port select XT2
UCS_initClockSignal(UCS_SMCLK, UCS_XT2CLK_SELECT, UCS_CLOCK_DIVIDER_16);
UCS_turnOnXT2(UCS_XT2_DRIVE_4MHZ_8MHZ);
UCS_turnOnSMCLK();
UCS_setExternalClockSource(32000, 4000000);
UCS_enableClockRequest(UCS_SMCLK);
#pragma vector = TIMER0_A0_VECTOR
__interrupt void __isr_Timer_A(void)
ucsFault = 1;
switch(TA0IV)
case 0:
Timer_A_clearTimerInterrupt(0x0340);
Timer_A_clearCaptureCompareInterrupt(0x0340, TIMER_A_CAPTURECOMPARE_REGISTER_0);
Timer_A_clearCaptureCompareInterrupt(0x0340, TIMER_A_CAPTURECOMPARE_REGISTER_1);
P1OUT |= BIT0;
ucsFault = 2;
break;
case 2:
P1OUT &= ~BIT0;
ucsFault = 3;
break;
