How to set in HFSS to get the normalized radiation pattern?
luobowr
Newbie level 3
Newbie level 3
hfss radiation pattern
How to set in HFSS to get normalized radiation pattern? Thank you very much!
akedar
Full Member level 5
Full Member level 5
radiation pattern hfss
i also need the answer
ayy2023
Junior Member level 3
lets think you are looking for normalized dB. Gain
what should you do?
here's the answer:
in the trace section write:
dB(GainTotal)-max(dB(GainTotal))
this will give you normalized rad. pat. for gain total.
for other stuff you can do the same thing.
dark_blue
Re: How to set in HFSS to get the normalized radiation patte
Hello everyone,
I just stumbled upon this thread and was wondering if the gain conversion to decibels using GainTotal and the function dB is actually correct.
The function dB calculates 20*log10(QUANTITY). However, since GainTotal is 4*PI*RADIATION_INTENSIY/P_ACCEPTED, GainTotal should be converted to decibels using 10*log10(GainTotal). Consequently, the correct conversion should be (dB(GainTotal)-max(dB(GainTotal)))/2, right?
Best regards
