How to set a second bit of the register ?
littlefield
Junior Member level 3
A small computer has an 8 bit CPU and only one register.
XOR - is the only assembly command it understands.
The initial state of the register is unknown.
Hi.
I did not clearly understand your question. As far as i understood, u can write a value to the register if you know the address of that register.
If the initial value of the register is '0' u can use the instr
XOR BIT, '1';
Hope it helps.
Thanks
do you need to keep other bits same as their original value? Or it is OK to clear them to 0?
You can do this by using the following two steps:
XOR BIT, BIT; --> will reset the bit
XOR BIT, '1'; --> will set the bit
Hope this works!!
Regards
Ganesh S
if u want to have the other bits unchanged it is imposible. u need at least to register to do this. but the other bits is not important for u do like this:
(a is your register)
a= a xor a
a = a xor 04h
LaTeX Commands Quick-Menu:
