How to send picture sms with PDU?
traxonja
sms pdu
Hi!
Does anybody know how to send operator logos, graphic messages, ringtones (poly/mono, does not matter yet) via GSM and PDU format.
I've managed to send simple text messages with PDU format and with a Siemens GSM phone. Now, I will probably use Nokia GSM (so it would be nokia to nokia sending).
Does anybody know what are the prefixes of that kind of PDU message (for ringtones or logos). I just can't find it on the net
Any tips would be great. I will probably write an application in Delphi (it doesn't matter, but anyway...).
One more thing. While I was sending SMSs with S25 Siemens, I have noticed that the maximum text (message) length is 48 chars??? Why is that???
All best,
Trax
www.elektronika.ba
artem
Turkey
send 8bit pdu
PLease have a look to book already uploaded here :
hxxp://www.elektroda.pl/eboard/searchtopic65181-sms.html
The issue you asked is already explained there .
Ringtones and logos most probably is proprietary implementation done by manufactoring companies .
The play with information within PDU to divert received message reaither to internal application than to user .
Related to Siemense , may be in PDU mode it can send up to 160 if packed 7 bit format or 140 unpacked 8 bit coding .
Ask Siemens support for detailed infromation .
traxonja
pdu picture sms
THANKS ALOT MAN!
About the Siemens now, I allready packed it. 7bit encoding (pdu). As described in AT Command Set for Siemens S25 document, Siemens only supports 7bit coding alphabet (PDU) for sending SMS.
I will check now the link you have posted. Thanks.
Trax
itsfanidotcom
Member level 5
maximum text for pdu
hi there i need to know how to send the text message using pdu mode...i know to send through text mode but i cant understand the pdu mode...and book or article which guides me to understand pdu mode?
thanks
