how to send data from clent to server via GPRS modem?
wildfyr8
Hello people I am in need of program or coding that is a Server is connecting to number of clients and each client is needed to respond on server request and confirm it working.
My idea is:
I am using GPRS modem with sim card on this plan. To recognize individual client that is GPRS modem should sent MAC address of the client to server page constantly when it is ON.
Or
Default notepad stored in the client system with individual pin or code should be sent to server page when it ON and it should sent it for every hour.
These information need to be send to server to recognize client.
I am very much happy to welcome new idea
Please help me out to solve this issue
Regards,
Wildfyr.
GSM Man
Banned
New Jersey, USA
By definition, a server is a device tat accepts incoming requests, and a client makes requests to a server. That is, a client intiates the connection to a server.
wildfyr8
need more info about this type of project...
i am using gprs AT modem it will be connected to client system here the problem will be client should be running automatically with the program created by me...now i need a program to track all these client from certain system(i.e., server page)
client system should send the mac id or any private pin to differentiate from other client.
HHM
Junior Member level 1
Hi,its important that when you connect to theh GPRS via your modem ,your IP Address which assigned to the GPRS Modem is Routable or not,your IP Address is Routable?
wildfyr8
i can be done in both ways..either in static or dynamic... so it's not a problem
HHM
Problame is not static or dynamic,its in Routable IP or not Routable IP.
Can you ping your clients IP Address via GPRS Connection ?
In my country we can not ping GPRS modules,did you test it?
wildfyr8
that's not a problem here ..i think so... ping it
GSM Man
Banned
New Jersey, USA
I don't know what country you are in, or what service provider you have, but all of them that I know of do not provide a routable IP address unless you have a plan that specifically provides one - usually at an additional cost.
Even if your address is routable, you won't get a PING response unless your device is configured to respond to an ICMP echo request.
