how to send AT commands through C
champnim
Junior Member level 2
i want to control a mobile phone from my pc using a program written in C. i want to know how to send the required AT commands through the C program.
KH
Junior Member level 1
I assume u have all the hardware interfacing ready.
1) Open the serial communication port using CreateFile
2) Set the baudrate, stopbits, etc using SetCommState
3) Read and write to the serial com using readfile and writefile
4) Assume u wish to send AT+OK, convert "AT+OK" to ascii, and send it using writefile.
Thanks.
Altafhal
Member level 2
Pakistan
First convert each character of the AT command to hex code and then send it serially or send it without converting to hex.
KH
Convert to ASCII hex first then only send it serially.
However, if the buffer use to hold the AT command is declared as char, it may not need to convert to Ascii hex 1st, but can send the command direct.
Not sure about this method, just an idea.
champnim
I'm trying to send "AT\r" to my phone but writeFile is giving an error(no. 87)...pls tell me what is wrong
#include <iostream>
#include <windows.h>
#include <string.h>
int main()
DCB dcb;
HANDLE hCom;
BOOL fSuccess;
OVERLAPPED o;
DWORD dwEvtMask;
char buffer[2048];
char *pcCommPort = "COM4";
hCom = CreateFile( pcCommPort,
GENERIC_READ | GENERIC_WRITE,
0, // comm devices must be opened w/exclusive-access
NULL, // no security attributes
OPEN_EXISTING, // comm devices must use OPEN_EXISTING
FILE_FLAG_OVERLAPPED,
NULL // hTemplate must be NULL for comm devices
if (hCom == INVALID_HANDLE_VALUE)
// Handle the error.
printf ("CreateFile failed with error %d.\n", GetLastError());
return (1);
fSuccess = GetCommState(hCom, &dcb);
if (!fSuccess)
printf ("GetCommState failed with error %d.\n", GetLastError());
return (2);
// Fill in the DCB: baud=9600 bps, 8 data bits, no parity, and 1 stop bit.
dcb.BaudRate = CBR_9600; // set the baud rate
dcb.ByteSize = 8; // data size, xmit, and rcv
dcb.Parity = NOPARITY; // no parity bit
dcb.StopBits = ONESTOPBIT; // one stop bit
fSuccess = SetCommState(hCom, &dcb);
if (!fSuccess)
printf ("SetCommState failed with error %d.\n", GetLastError());
return (3);
printf ("Serial port %s is successfully reconfigured.\n", pcCommPort);
//char *command="A";
unsigned long byteswritten;
if(!WriteFile(hCom,"AT\r",3,&byteswritten,NULL))
printf("WriteFile failed with error %d.\n", GetLastError());
return (4);
//printf("String %s successfully written to %s port",command,pcCommPort);
KH
I always use this way to send data
BYTE data[5]={0};
DWORD byteswritten;
BOOL returnValue;
BYTE bytes2send;
data[0]=0x41; //AScii A
data[1]=0x54; //AScii T
data[2]=0x5C;
data[3]=0x72;
bytes2send = 4;
returnValue = WriteFile(hCom,&data,bytes2send,&byteswritten,NULL);
if fail again, maybe can try replace the \r with carriage return, as below :-
data[2]=0x0D //Ascii for CR
bytes2send = 3;
Hope it helps.
