trashbox
Hi all,
I want to select a high speed phase frequency detector,which can be operated up to 2.5GHz.And I want to use this PFD in PLL(it's output is not a quadrature signal). In other words,the PLL's input reference CLK is 2.5GHz.
I don't know whether the conventional tri-state phase frequency detector can meet this requirement?Would you recommend any phase frequency detectors which can work under 2.5GHz?
Thank you very much.
