The best way is that once I have modified the layout, then I only need to run the script and it will auto export the gds/netlist and run lvs/drc, then I only need to check the result, anyone have any idea about this?
Please clarify if you need the script.
It is the calibre command you need to call in a shell script.
The inputs are to be processed before u provide them to the command.
Please play with the calibre runset file, to automate the lvs or drc process.
