How to run cadence on 16-bit color mode
robertos
Newbie level 1
Maybe its eassy but I have no clue how to do it. I have tried to instal icfb on wirtual machine (windowsXP - WM - linux), but when I tried to run ICFB, I got an error: Error: Failed to finde either 24-bit True Color or 8-bit PseudalColor Visual.
On 8-bit mode it works but I´m not able switch the grafic card to 24-bit mode in Linux -> I mean Linux under - WirtualMechin - WindowsXP32 bit mode. I guess it´s because winXP work with 32 or 16 bit color mode.Therefore I´d like to run ICFB on 16-bit depth color mode. Do you have any idea how to do it ?
ckshivaram
Advanced Member level 5
villingen (Germany) / Bangalore
There is a bug using 16 bit color in 2.2.6. If you set your client to 32 bits this should fix the color issue.
The next release of GGUX - 2.2.8 fix this 16 bit color problem.
---------- Post added at 22:07 ---------- Previous post was at 22:01 ----------
i dont know if this answers your question
Commercial Software - Cadence Design Framework II
