yasharA
Newbie
Hi all
i have connected ADS to MATLAB and Matlab can run ADS netlists, but i have problem when i want to run a netlist which has ADS PTOLEMY functions such as input file reader.
when i want to run this netlist inside matlab, it gives me this error
Error detected by hpeesofsim during netlist flattening.
Could not load tsdfgemstars: The specified module could not be found..
Running the simulation from the command line may give a more detailed
error message. See the "Building Signal Processing Models From the
Command Line" chapter of the Ptolemy manual for instructions on how to
do this."
i hould emphasis i can run this ADS file directly but when i am using " system('hpeesofsim netlist.log');" function inside MATLAB to run this netlist it gives me error. and it is just happened with this netlist( ADS file which has ptolemy functions).
would you please help me to tackle this problem?
Best regards
YASHAR
do this."
Best regards
YASHAR
