how to route difference pair in allegro?
kimjin
Member level 3
Member level 3
i can't add difference pair .
who can dipict the sketch of route a difference pair, thanks.
hi
Differential mode involves a pair of traces (wires) between
the driver and receiver.s the following are the important facts to be considered while routing
>traces should be of equal length.
>route differential traces closely together.
>the separation between the two traces (of the differential pair) must remain
constant over the entire length.
>trackwidth should be same for both the traces
you can assign the trace width, physical type incontraints.
then as neena said the trace should be equal length, pair should run parallely with specified space in all the area.
First you have to assign the not nets or xnets as differential pairs.
Specify clearly the trace length & track to track spacing.
In case you are not able to get this. try to run the pairs to be routed parallel from source to destinatio (this mentod is not recomended.)
Dear
As sugvivek said u can Use Constraint maneger to constrain this net. to help U in routing ( help U mean he will intrrupt u if U route this track differ from your constrain
U can assigen Diff pair from allegro
(logic>Assiegn diff. pair)
