How to rotate a component in Orcad Layout Plus
Roel
Member level 2
Member level 2
Belgium
How do you rotate a component 45 degrees in Orcad ?
You can rotate a component 90 degrees by pressing the 'R' button. But I like to rotate my component an other angle.
Roel
In layout go to the menu
Option---->System settings
Then fill the degree in Rotation Increment
Or simply edit the components properties and set any angle you desire.
Just keep in mind that the component with rotate about its origin, which is not necessarily the "center" of the component.
