How to reverse the order of bits in VHDL?
voho
Full Member level 2
Full Member level 2
Nador City
Hi all,
I have a vector A(15 downto 0)=0000 0000_000F FFFF
how to do in VHDL in order to obtain B(15 downto 0)= FFFF F000_0000 0000
Thank's in advance
Re: complement in vhdl??
Please say again what do you want to do because you do some mistakes.
First you say that the vector has 16 bits and you give to it a 64 bits value.
Second , by the way you wrote there I think that you want to reverse the order of the bits in the vector.
you must write :
B(15)<=A(0);
B(14)<=A(1);
B(13)<=A(2);
B(12)<=A(3);
B(1)<=A(14);
B(0)<=A(15);
Hi All,
Of course A(63 downto 0) and B(63 downto 0).
Thank's master.ro for your help.
Regards
it's not clear yet what do you want: to reverse the order of the bits as you say earlyer or to calculate the complement?
if you want the complement :
B(63 downto 0) <= not A (63 downto 0);
or
B(63 downto 0) <= not A (63 downto 0) + '1';
To reverse the order of bits without having to do it long-hand
process(A)
begin
    for i in A'range loop
        B(B'left - i) <= A(i);
    end loop
end process
This should be synthesisable. My use of B'left assumes that A and B are both defined with the same range (63 downto 0 in your case).
You don't need to loop or anything, this simple statement will do:
B(0 to 63) <= A(63 downto 0);
Cheers.
