[SOLVED] How to retun an Array to a function?
agg_mayur
Member level 3
Member level 3
India
Dear All,
Please tell me how to retun an array to a function. For e.g. i want to print Name
class office{
char name[4];
int emp;
public:
void set_name(char *n);
char get_name();
void set_emp(int e);
int get_emp();
void Office::set_name(char *n)
memcpy(&name,n,4); //Is it right
void Office::set_emp(int e)
emp = e;
char Office::get_name()
return *name; //How to return whole array to a function//wants modification
int Office::get_emp()
return emp;
int main()
char n[4] = "ABC";
Office o;
o.set_name(n);
o.set_emp(457);
cout << "Company Name is " << o.get_name();
cout << "\n"; cout << "\n";
cout << "No. of Employees are " << o.get_emp();
cout << "\n";
return 0;
return a pointer to (the address of) name[], e.g.
char * Office::get_name()
return name; //How to return whole array to a function//wants modification
Re: How to return an Array to a function?
Thanks for the reply, it works. Is there any harm to return an local array?
Also please describe me how it works(above solution)?
you were returning a pointer to a global array which is OK.
do not return pointers to variables or local arrays, e.g.
char * get_name()
    char name[20]="joe";
    return name;
local variables are allocated on the stack on entry to the function and lost on exit therefore using such a returned pointer would destroy the stack integrity
given the above code the gcc compiler gives a warning
c1.cpp|3|warning: address of local variable 'name' returned|
Reactions: agg_mayur
    agg_mayur
    KMS17
