With the circuit attached, all are mounted on BREADBOARD and power supply(PHASE and Neutral, 230v/50hz)) taken out from a SWITCH BOARD (230v/50hz) through a EXTENSION BOARD(230v/50hz) and all are exercise on BREADBOARD and EXTENSION BOARD.
All are working as EXPECTED, But
Problems are, whenever any Switch/s (connected at appliances, like FAN and Fluorescent Tube Light with magnetic choke coil) from SWITCH BOARD is turn ON/OFF then, the BREADBOARD output(ie, Triac Output, Output1/Output2 connected with Incandescent Bulbs ) gets Flicker Once on every pressing of Switches from the SWITCH BOARD. And
It also notice that the BREADBOARD output/s gets turn ON/OFF SOMETIMES on pressing of switch from SWITCH BOARD to turn off and on the connected load of SWITCH BOARD.
Briefly, it can be said, BREADBOARD circuit get response on opening/closing of switches from SWITCHBOARD.
Could you please let me know HOW to resolve this malfunction??
many thanks all of you...
