how to reset SMBus of netbook battery?
mornster
Newbie level 3
Newbie level 3
philippines
Good day every everyone!.. im from Philippines and im glad to be here in Edaboard.com. by the way does anyone know how to reset SMBus of netbook battery?
the problem is when i plug in my charger it works fine but when im unplug the charger it shut off automatic in a blink on eye. the battery have 58% charge but can't power on my netbook. in the next day drop to 54% but it indicates "charging" in the icon. the following day drop to 51% still can't power on.
I dont know if my battery is DEAD?! or the SMBus was shunt off because they reach the life cycle of the battery.
Is there anything i can do to reset SMBus so that the battery will start in the begenning life cycle.
Pls help... your help or idea will be appreciated.. :cry:
It wont be the smbus, that just puts out the values calculated by the battery. It looses capacity each time it is cycled (this is non-recoverable) and if the aging algorithms are rubbish or don't exist eventually what you are seeing will happen. This once happened to my laptop battery. It is stuffed i'm afraid.
+++++++++++++++1
thank you for your information Nickdean1. reply to Nickdean1----> so if wont be the SMBus.. what should i do? i'll go buy for new one netbook battery?
A laptop battery may have only one weak cell, and the success rate of replacing the affected cell depends on the matching with the others. All cells in a pack must have a similar capacity because an imbalance shortens the life of the pack. Read more about Can Batteries Be Restored?. Furthermore, the state-of-charge of all cells being charged for the first time should have a similar charge level, and the open-circuit voltages should be within 10 percent of each other. Welding the cells is the only reliable way to get dependable connection. Limit the heat transfer to the cells during welding to prevent excess heat buildup.
The typical SMBus battery has five or more battery connections consisting of positive and negative battery terminals, thermistor, clock and data. The connections are often unmarked; however, the positive and negative are commonly located at the outer edges of the connector and the inner contacts accommodate the clock and data. (The one-wire system combines clock and data.) For safety reasons, a separate thermistor wire is brought to the outside. Figure 1 illustrates a battery with six connections.
Terminal connection of a typical laptop battery
Figure 1: Terminal connection of a typical laptop battery
The positive and negative terminals are usually placed on the outside; no norm exists on the arrangement of the other contacts.
Courtesy of Cadex
Some batteries are equipped with a solid-state switch that is normally in the “off” position and no voltage is present on the battery terminals; connecting the switch terminal to ground often turns the battery on. If this does not work, the pack may need a proprietary code for activation, and battery manufacturers keep these codes a well-guarded secret.
How can you find the correct terminals? Use a voltmeter to locate the positive and negative battery terminals and establish the polarity. If no voltage is available, a solid-state switch in the “off” position may need activating. Connecting the voltmeter to the outer terminals, take a 100-Ohm resistor (other values may also work), tie one end to ground, and with the other end touch each terminal while observing the voltmeter. If no voltage appears, the battery may be dead or the pack will require a security code. The 100-Ohm resistor is low enough to engage a digital circuit and high enough to protect the battery against a possible electrical short.
Establishing the connection to the battery terminals should now enable charging. If the charge current stops after 30 seconds, an activation code may be required, and this is often difficult if not impossible to obtain.
Some battery manufacturers add an end-of-battery-life switch that turns the battery off when reaching a certain age or cycle count. Manufacturers argue that customer satisfaction and safety can only be guaranteed by regularly replacing the battery. Such a policy tends to satisfy the manufacturer more than the user, and newer batteries do not include this feature.
If at all possible, connect the thermistor during charging and discharging to protect the battery against possible overheating. Use an ohmmeter to locate the internal thermistor. The most common thermistors are 10 Kilo Ohm NTC, which reads 10kΩ at 20°C (68°F). NTC stands for negative temperature coefficient, meaning that the resistance decreases with rising temperature. In comparison, a positive temperature coefficient (PTC) causes the resistance to increase. Warming the battery with your hand may be sufficient to detect a small change in resistor value when looking for the correct terminal on the battery.
In some cases the chemical battery can be restored, but the fuel gauge might not work, is inaccurate, or will provide wrong information. After repackaging, the battery may need some sort of initialization/ calibration process. Simply charging and discharging the pack to reset the flags might do the trick. A “flag” is a measuring point to mark and record an event.
The circuits of some smart batteries must be kept alive during cell replacement. Disconnecting the voltage for only a fraction of a second can erase vital data in the memory. The lost data could contain the resistor value of the digitized shunt that is responsible for the coulomb counter. Some integrated circuits (IC) responsible for fuel gauge function have wires going to each cell, and the sequence of assembly must to be done in the correct order.
To assure continued operation when changing the cells, supply a secondary voltage through a 100-Ohm resistor to the circuit before disconnection and remove the supply only after the circuit receives voltage again from the new cells. Cell replacement of a smart battery has a parallel with open-heart surgery, where doctors must keep all organs of the patient alive.
Anyone repairing an SMBus battery needs to be aware of compliance issues. Unlike other tightly regulated standards, the SMBus allows some variations, and this can cause problems when matching battery packs with existing chargers. The repaired SMBus battery should be checked for compatibility before use. More information on SMBus is available on www.sbs-forum.org and www.acpi.info.
this info is coming from (http://batteryuniversity.com/learn/article/how_to_repair_a_laptop_battery)
