How to reset PIC in Software?
UroBoros
Advanced Member level 2
Cochin - India
pic16 mlcr
Hai
Which is the best method to reset a PIC from its own software?
Will a goto 00 clear the call stack?
picstudent
eng_ahmed22
Full Member level 3
Salam
i have small knowledg about the PIC. but i think u may use the WDT to reset the PIC.
just enable it when u want to reset the PIC after a while (depend on the value in the WDT).
hope that help u
Best Regards
Ahmed
    UroBoros
UroBoros
Cochin - India
Hai
My programe works in WDT disabled mode.
I doubt weather WDT can be enabled "on the fly"
Thanks
picstudent
IanP
Advanced Member level 5
West Coast
If you plan to use GOTO 00 as software reset you will need to add in the beginning of the code set of SETs/RESETs to specified registers, otherwise jump to 00 will be executed like any other jump ..
( see data sheet of a particular PIC for the reset values of crucial registers) ..
Another option, however not used very often, is to connect one of I/O pins to the MLCR and execute reset that way ..
Regards,
IanP
    UroBoros
NickE
Member level 1
PIC18 devices have RESET instruction.
On PIC16 there is no softreset, but it is possible to configure a peripheria (like WDT) to reset the chip.
    UroBoros
