How to rename a component's pin in Allegro 16.2?
antarveena1982
Member level 3
Hi all
how can one rename Pin rename of the component in allegro16.2?
regards
Antarveena
Re: Allegro pin rename
i think you can not edit pin name inside the design you can edit the Foot print (symbol) then update the package in the PCB file
Hi
If i made BGA with pin number 1 23--- and i want to convert the pin name by Alphanumeric code how can i achieve it ?
Regards,
Antarveena
Allegro pin rename
Like Antonios said you can edit the Foot print (symbol) then update the package in the PCB file.
@Antonios editing is possible in design file also but sorry I do not remember that exactly as it has been a while since I last used allegro
Hi
How can i rename pin in symbol editor in allegro16.2?
regards
Antarveena
Hi Ricky
Thanks a lot
regards
Antarveena
