xpress_embedo
Hello!! i am using MPLAB X with MPLAB C18 v3.40 Compiler and using PIC18F27J53 Micro-Controller.
I want to remove these warnings, i am getting
I had Written a simple LCD Program, to display data on LCD, and now wants to make a function, with which i can pass the first address of the array and it displays whole string.
For example:-
unsigned char text[] = "EDA BOARD";
and
Lcd_Text(text);
will display it on LCD, i had done it but getting a warning in this, pls help me to correct it.
This is my Code
I am getting both warning in this code.
Please suggest me something to solve this warning issue.
Although my code is working fine as expected, just want to remove this compiler warning
Warning [2054] suspicious pointer conversion
and
Warning [2066] type qualifier mismatch in assignment
For example:-
and
Lcd_Text(text);
This is my Code
#include <p18F27J53.h>
#include <delays.h>
#include <string.h>
/******************CONFIGURATION BITS****************/
#pragma config WDTEN = OFF //WDT disabled (enabled by SWDTEN bit)
#pragma config PLLDIV = 5 //Divide by 5 (20 MHz oscillator input)
#pragma config STVREN = ON //stack overflow/underflow reset enabled
#pragma config XINST = OFF //Extended instruction set disabled
#pragma config CPUDIV = OSC1 //No CPU system clock divide
#pragma config CP0 = OFF //Program memory is not code-protected
#pragma config OSC = HSPLL //HS oscillator, PLL enabled, HSPLL used by USB
#pragma config FCMEN = OFF //Fail-Safe Clock Monitor disabled
#pragma config IESO = OFF //Two-Speed Start-up disabled
#pragma config WDTPS = 32768 //1:32768
#pragma config DSWDTOSC = INTOSCREF //DSWDT uses INTOSC/INTRC as clock
#pragma config RTCOSC = T1OSCREF //RTCC uses T1OSC/T1CKI as clock
#pragma config DSBOREN = OFF //Zero-Power BOR disabled in Deep Sleep
#pragma config DSWDTEN = OFF //Disabled
#pragma config DSWDTPS = 8192 //1:8,192 (8.5 seconds)
#pragma config IOL1WAY = OFF //IOLOCK bit can be set and cleared
#pragma config MSSP7B_EN = MSK7 //7 Bit address masking
#pragma config WPFP = PAGE_1 //Write Protect Program Flash Page 0
#pragma config WPEND = PAGE_0 //Start protection at page 0
#pragma config WPCFG = OFF //Write/Erase last page protect Disabled
#pragma config WPDIS = OFF //WPFP[5:0], WPEND, and WPCFG bits ignored
#pragma config CFGPLLEN = OFF
/****************PIN DETAILS****************/
#define LCD_RS PORTCbits.RC0
#define LCD_RW PORTCbits.RC1
#define LCD_EN PORTCbits.RC2
#define LCD_DATA PORTB
#define CURSOR_OFF 0x0C
#define LCD_CLEAR 0x01
#define FIRST_ROW 0x80
#define SECOND_ROW 0xC0
/******************FUNCTION PROTOTYPE*******************/
void Delay_ms(unsigned int itime);
void Lcd_Init(void);
void Lcd_Cmd(unsigned char value);
void Lcd_Data(unsigned char value);
void Lcd_Text(unsigned char *msg);
rom unsigned char text[] = "EDA BOARD";
void main()
Lcd_Init();
Lcd_Text(text);
while(1);
#ifndef __DELAY_IN_SEC
#define __DELAY_IN_SEC
unsigned int first;
unsigned int second;
#endif
for(first=0;first<itime;first++)
for(second=0;second<650;second++)
Delay1TCY();
LCD_DATA = value;
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 1;
Delay_ms(2);
LCD_EN = 0;
Delay_ms(1);
LCD_DATA = value;
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 1;
Delay_ms(2);
LCD_EN = 0;
Delay_ms(1);
void Lcd_Init(void)
TRISB = 0x00;
TRISCbits.TRISC0 = 0;
TRISCbits.TRISC1 = 0;
TRISCbits.TRISC2 = 0;
Lcd_Cmd(0x38); //Lcd_Initialize
Delay_ms(10);
Lcd_Cmd(CURSOR_OFF);
Delay_ms(10);
Lcd_Cmd(LCD_CLEAR);
Delay_ms(10);
Lcd_Cmd(FIRST_ROW);
Delay_ms(5);
#ifndef _LCD_STRING_LEN
#define _LCD_STRING_LEN
unsigned char len;
unsigned char pointer;
#endif
len = strlen(msg);
for(pointer=0;pointer<len;pointer++)
Lcd_Data(msg[pointer]);
