dick_freebird said:I do not notice any glitches in the waveform plots.
dick_freebird said:I think that is the Miller capacitance, pushing back on a weak
gate discharge. Perhaps you want more tail current. Or
perhaps less finger count in the switching pairs. Current
density tends to maximize speed. That CML gate is basically
a tall cascode amplifier, high impedance at the drain.
High Z tends to lower bandwidth. To that end, have you
played with shortening the bias devices? Lower Zout might
"up the bandwidth" at the upper gates.
LvW said:To me it looks like the result of parasitic oscillations within the circuit.
To check it, remove the input and terminate the input by the proper source impedance.
prcken said:LvW said:To me it looks like the result of parasitic oscillations within the circuit.
you meant try to tie the input through a proper resistor to ground?
the waveform of the inputs seems ok, this the input waveforms after the AC capacitance.
LvW said:prcken said:LvW said:To me it looks like the result of parasitic oscillations within the circuit.
Yes, but without any input signal you can see if there are parasitic oscillations!
karesz said:Hi prcken,
Sorry, but if Im right; your circuit oscillates inself, than these signal will interfer with your input or regular signal...
These is the effect of form changes too if your tested-simulated frequency are changed/lowered! :-(
Good progress!
K.
karesz said:OK,
These function was new for me-tnx!
Other question, that a signal output has to be clean here too, but you knows it...
K.
love_analog said:prcken
What process is this in? You see the voltage is >1.1V.
Also can you post a schematic of the circuit. That will help.
