mann4uonlyed
Newbie level 5
as i synthesize then i got an error for mapping as error map 116 and said that entry is empty, is there any process to use IP from Core Gen
---------- Post added at 14:53 ---------- Previous post was at 14:49 ----------
there are so many error as Ngd build: 578
Error: Projectmgmt:496
error:complier:806
may i get the solution for this
or is the reason that there is any license required
As i get the msg that you can not use the source code?
---------- Post added at 15:00 ---------- Previous post was at 14:53 ----------
Is there any way to get those IPs cracked that are available in Core Generator
error:complier:806
