How to remove effect of antenna from measurement result
amir_rch
Junior Member level 3
hello friends
can you tell me how to remove the antenna effect from measurment results?
i measured S21 with dipole antenna but this antenna have a little difference between simulation and measurment.
Azulykit
All over the Map.
You might find the Wheeler Cap measurement technique useful. I suspect that you might be after an efficiency measurement or a method for separating directivity and gain.
Regards,
Azulykit
