how to remove assign in netlist file which generate by astro
xworld2008
Full Member level 4
When we after place and route by astro, we generate a netlist file, and the netlist file have some assign command, such as :
assign cpu_rst_n = rst_n
how to remove such assign command ,please help me.
Why do you want to remove the assignment statement?
Let it be ...
you can read in into dc ,and use set_fix_mulitple_port_nets –feedthroughs set_fix_multiple_port_nets –all –buffer_constants
You can remove assign statement in DC according to jjww110's guide.
What I wonder is that this is a bug of ASTRO? ASTRO knows physical connection, it shoud regard these two net as the same one.
