Register Log in
How to relate polarization to theta and phi components of the electric field?
mprathap
Member level 1
I measured the horizontal and vertical polarized components of an antenna. How do I relate this to theta and phi components of the electric field. I figured it out to be as vertical component = theta component and horizontal component = phi component. But when I compared it with simulated results from HFSS it turns out to be the other way around. i.e., vertical = phi and horizontal = theta.
I gave a lot of thought on this, and after researching through Google, and going back to some basic vector field algebra, it is not still quite clear to me.
Any help would be greatly appreciated.
Element7k
Advanced Member level 1
TherealLapland
ephi,etheta spherical
Hi mprathap,
it may help when drawing your antenna to align your antenna's main electric fields vector in the Z-direciton and the orthogonal field in the xy plane. Try a simple dipole for a start. Hope it helps.
Rgz,
E7k
GVVIN
antenna gain from e-phi and e-theta
see attached
theta and phi in Spherical co ordinate system
demian1977
Member level 1
ethet fields
Antenna orientation in a reference systems is arbitrary. You should orientate the antenna when you mesure it and in HFSS in the same way.
Don' confuse the angle beetwen axes x,y,z and versor theta and phi.
Toggle Sidebar
