Murugesh_89
Full Member level 5
- Joined
- Nov 23, 2012
- Messages
- 266
- Helped
- 7
- Reputation
- 12
- Reaction score
- 6
- Trophy points
- 1,298
- Location
- India
- Activity points
- 3,267
Below i put my setup with the value of voltage at the input of each board.
I am using a 12V smps. Each board in the setup draw a current of 300 mA. Now for 5 boards the current drawn from smps is 1.5 A.
Actually i need to get the supply for 20 boards using a single smps. But for now, with 5 boards itself the voltage reduce to 11.15 for fifth board. So i fear that i wont enough voltage (atleast 10.5 V as i have used 7808) at the last 20th board. Also i think when i go for 20 boards the load current will be around 6 A which cause more drop. I should not run individual wires from smps to each board.
So,
1. How can i get out from this issue so that i can get around 10.5 V at the last board.
2. How to measure the resistance in supply path. I want to know across which terminals?
3. I have regulated 5V and 8V directly from the 12V in each board, will it have anything to do with the more voltage drop issue. I mean if i regulate 5V from the output of 7808 will it be fair?
Thanks,
Murugesh
So,
Thanks,
Murugesh
