How to reduce the temperature of SMPS transformer?
zyrixx
Newbie level 5
can someone please help me in reducing the temperature of the power transformer...
what should be done? should i decrease the freaquency?
thnxs in advace
satya_vijayawada
Full Member level 2
Re: SMPS transformer
give me the full details (like core size output power ..........)
or
try this
www.powerint.com
search for AN-18.pdf (flayback transformer construction guide)
satya
:D
vanko1tempg
SMPS transformer
you maybe increase the core size and the wire size.
munich1806
Junior Member level 1
You may induce gap between winding for better heat sink.
wisepie
Member level 4
If reduce the frequency will increase the core temperature. Probably you can use bifillar winding rather than single wire. This will reduce the ac resistance or the skin effect.
Added after 1 hours 21 minutes:
How to introduce gap in winding?
zyrixx
Newbie level 5
actually what i know is its output power is 500W and it is a planar transformer. the wires are tripple insulated already...
the topology is full bridge and i have tried varying the blocking cap
thnks
munich1806
put stripped paper between winding.
wisepie
Member level 4
I dont think this is a effective way.
