Thresholds levels can be obtaining for a particular ratio of transistors.
Design your Schmitt trigger for minimum Beta values by which you
can reduce the current.
in fact, you can add extra two resistors connected the vdd and vgnd respectively to limit the current. the tech is applied in actual ICs.
wish it can help u.
