First, we know Shot Noise in BJT is modelled by Sq(I noise) = 2.q.(Ave I), where I noise = Average Current due to Shot Noise developed across a Potential Barrier such as a PN Junction between Collector and Base, and Ave I = DC or Average Current flowing across this Barrier, and q is the unit charge.
To reduce Shot Noise, you have to reduce the Ave I.
You can use a BJT with lower HFE (DC or Forward Current Gain between Base I and Collector I). Lower HFE is in fact better for high-frequency devices, such as one used as VCO, because lower HFE offers lower quiescent or static power consumption, and lower heat dissipation. Lower HFE only has lower DC current gain but this should not affect AC signals such as one for high-frequency circuits.
Alternatively, you can use a collector feedback or common-base, but this will reduce the overall voltage and current gain. Instability is a problem when using collector feedback due to oscillator and high-frequency noise can be injected from the output back to the input.
