how to reduce spikes in inverter without using out put capac
prasadel06
Member level 2
hi....
i am using inverter in my project....i am using 130 nm tech...
and i am getting spikes...please help me in reducing the spikes in
the output of the inverter...
thank you..
prasad
Re: how to reduce spikes in inverter without using out put c
You can reduce glitches at transition edges by reducing clock feedthrough. this can be achieved by reducing transistors' sizes or by reducing the transition slope of the input waveform.
You also may consider bypass capacitors. What is the frequency of the chopper? Once you know the chopper frequency, calculate the Xc for the bypass capacitors to be 0 Ohms. Then consider using ferrite beads on the output wires for that frequency range. That should reduce a fair amount of the noise from the chopper.
generally switching transistors cause glitch due to kickback noise and clock feedthrough and hence these are generally separated from the input and output using a transistor which is always on......
