How to reduce noise of a speech signal?
malaguena
Newbie level 5
Hello everybody,
I have to reduce the noise of my speech signal. Are there any tested algorithms, written code or implemented programs that I can use within my application to speed up my coding duration?
Thanks for your help,
best wishes
A.Anand Srinivasan
Advanced Member level 5
India
Re: How to reduce noise?
can you give details on through which you are passing the signal or the software which you are using to simulate the coding of your speech signal....
malaguena
Newbie level 5
I will use it within my thesis. My thesis is on speech recognition, but before the feature extraction process, I have to reduce the noise of the signal.
A.Anand Srinivasan
India
the main thing is bandpass filtering which removes noise outside the frequency range of interest.... next there is a need for echo cancellation which is due to reflection and other imperfections.... there are many algorithms for echo cancellation based MMSE, ML etc.... the other inherent noises are hard to reduce and are mostly due to channel....
ebook123456789
Member level 2
the first thing is to understand the source of your noise. different noise needs different treatment.
malaguena
Newbie level 5
I alread tried lowpass filtering. Then as you recommended, I will search echo cancellation..
Thanks for your help..
Added after 1 minutes:
How can I determine the source of noise?
echo47
USA
To clarify ebook123456789's question, what kind of noise is it? What does it sound like?
If you can't identify the noise, maybe upload a small sample file that we can play.
If you attach the file to an EDAboard message, you'll need to ZIP it or RAR it first.
