how to reduce harmonics in ios
MetalLord
Junior Member level 1
Hi all
is there any way we can reduce harmonics at the output stage of an io output buffer which has architecture like corelevel signal -> levelshifter->predrivers->GTO driver -> output to the pad..
one way is putting filter (Band Pass), by using select suitable RC filter
Make sure of enough overdrive (cmos) or degeneration (bjt). degradation starts at overdrive/1.414. any overdrive problems leads to harmonics. slew rate limitation will also cause sine to be distorted, hence each stage should be biased with sufficient current. hope this helps.
Can you afford feedback control?
A high speed opamp (either voltage mode or current mode) shall serve you well in moderate frequency applications.
Actually emitter degeneration is a feedback example essentially.
If you run at high frequency, try feedforward/preditortion as in PA design.
External bandpass / low pass filters are quick fix. But you shall keep it as the last resort. Specially keep an eye on the stop band impedance of these filters.
