Hi, I am reading the paper "Broadband Impedance Matching Network for RF Power Amplifiers" and came across idea of realizing Inductor using microstrio line.
(1)As per the above formula, I can find what is the required length of the line for that particular inductor value. Anyone knows the same kind of formula for CPW line? And how do I know what should be the charateristic impedanced of the line, are there any conditions or procedures to choose it?.
(2)But as per below formulas also we can get inductance.
I know that (2) can be used while doing stub matching but we can also use (1) for matching, however it is just the substitutuon of inductor. I want to know which one to use when and any more insight on this. Thanks.
CPW cannot be used for Inductor Realizations.Especially if the frequency is not sufficiently high, making an inductor by using Transmission Lines is not practical at all..
CPW stands for co-planar waveguides. Transmission lines can be realized on-chip using co-planar metals as Ground-Signal-Ground configuration. It can also be realized by routing the signal trace on a different metal layer and ground on a different metal layer. Then its no longer CPW.
How to choose Z0?
Increasing Zo will mean that you get the same inductance for a shorter length of line --> lesser losses. Also, the bandwidth of matching using transmission lines increases when the impedance to be matched and the characteristic impedance are close to each other. Its an iterative process to get it right.
I also hope you realize that the first expression comes directly from the algebraic manipulation of a shorted stub.
