cascomio
Newbie level 3
- Joined
- Jan 15, 2013
- Messages
- 3
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,299
Hi guys,
I am new with the PICs and compilers and I have to use it in a part of a project.:| I am using the PIC184520 and the MPLAB 8.86 C compiler. Im trying to read txt file and send it by USART
My code:
I obtained this errors in the compiler:
There is something wrong with fopen and putrsUSART.
Thank you for your help and time!!
My code:
/* Serial Communication Transmit Example */
/* Using Port C as a USART Port */
#pragma config OSC = HS /*set osc mode to HS */
#pragma config WDT = OFF /* set watchdog timer off */
#pragma config LVP = OFF /* Low Voltage Programming Off */
#pragma config DEBUG = OFF /* Compile without extra Debug compile Code */
#include <p18f4520.h>
#include <delays.h>
#include <usart.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
void main ()
char ch;
FILE *fp;
/* Make Port C O/P */
TRISC = 0x00;
/* Set USART Parameters Baud rate 19.200 */
OpenUSART(USART_TX_INT_OFF & USART_RX_INT_OFF & USART_ASYNCH_MODE & USART_EIGHT_BIT & USART_CONT_RX & USART_BRGH_LOW, 15);
fp = fopen("test.txt","r");// read mode
while( ( ch = fgetc(fp) ) != EOF )
putrsUSART("%c",ch);
fclose(fp);
31:Warning [2058] call of function without prototype
31:Error [1131] type mismatch in assignment
33:Warning [2058] call of function without prototype
34:Warning [2066] type qualifier mismatch in assignment
34:Error [1204] too many arguments in function call
36:Warning [2058] call of function without prototype
