how to read the memory chipset SST39VF800 ?
ravi_p
Member level 1
Reading SST39VF800
Hi
Can anyone tell me how to read the memory chipset SST39VF800.
Thanks
Reading SST39VF800
I also want to find .you use arm or 51???
Re: Reading SST39VF800
Hi RogueBear
I use 8051
ABOUT THE SOFTWARE
This application note provides software driver examples for 39VF800A,
8 Mbit Multi-Purpose Flash, that can be used in any microprocessor based
system. Software driver examples used in this document utilize two programming
languages: (a) high -level "C" for broad platform support and (b) optimized x86
assembly language. In many cases, software driver routines can be inserted
"as is" into the main body of code being developed by the system software
developers. Extensive comments are included in each routine to describe the
function of each routine. The driver in "C" language can be used with many
microprocessors and microcontrollers, while the x86 assembly language provides
an optimized solution for x86 microprocessors.
