Mar 29, 2005 #1 I ilikebbs Advanced Member level 4 Joined Nov 30, 2002 Messages 104 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 705 I want to use fpga to read flash,now just read ,do not write. Anybody can give me some examples about this? thanks.
Mar 29, 2005 #2 T tongson Junior Member level 2 Joined Dec 24, 2004 Messages 24 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 159 Go to ipcore website and download the ip, then program your FPGA.
Mar 29, 2005 #3 I ilikebbs Advanced Member level 4 Joined Nov 30, 2002 Messages 104 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,298 Activity points 705 I can not use ipcore. I have to have the source code. Could you give me some verilog(vhdl) source code examples? thanks.
Mar 30, 2005 #4 C chinara Full Member level 1 Joined Sep 15, 2004 Messages 96 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,288 Activity points 842 You just looks the FLASH as a ram. When you read flash, it works like a ram.
Mar 30, 2005 #5 C coolsniper Junior Member level 3 Joined Feb 9, 2002 Messages 29 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 123 FLASH is SRAM!
Mar 30, 2005 #6 I it_boy Full Member level 3 Joined Jul 18, 2002 Messages 173 Helped 6 Reputation 12 Reaction score 2 Trophy points 1,298 Activity points 1,261 What kind of FLASH are you planning to use? If you are trying to access NAND FLASH, check memory section in the following link https://www.xilinx.com/products/xaw/downloads/index.htm
