How to read and write,and how to see the data in 6264 by MEDWIN?
eg_cwkab
Newbie level 3
I use UT-CPC6264-70LL
I don't know how to read and write,and how to see the data in 6264 by MEDWIN.
For read,I just need to MOVX A,@DPTR?
Re: About 8051 and 6264
To connect this memory to 8051 microcontroler you need 8-bitt address latch on A/D0, .., A/D7 (74373) .. Do you have it?
The CE1 pin can be connected to 0V, CE2 to +5V, OE to µC RD and WR to µC WR ..
Once you have all the above connction in place you can use MOVX instructions to read data from and write data to this RAM ..
Regards,
IanP
THX
I have the latch 74HC373
Do I need to SETB WE and CLR RE,before i write data?
No, you don't need to ..
If you use the MOVX instruction all is done automatically be the microcntroller ..
The /CE1 pin can be connected to 0V, CE2 to +5V, /OE to µC /RD and /WE to µC /WR ..
Regards,
IanP
Thanks a lot
And how can I see what data is inside the 6264 by using MEDWIN?
i write as the follow
org 00h
mov a,#11h
mov dptr,#0001h
movx @dptr,a
clr a
movx a,@dptr
but at the end,i just get a=00h,but not 11h
i do not know why...please help
thanks a lot
