How to put voltage limiter in a circuit using diode ?
Shreehari
Member level 4
mangalore
I was asked to put voltage limiter in the circuit using diode. I have to put limitation around -10V to+10V range. How can I do that?
Re: Help Voltage Limiter
You can connect 2X 9.1V Zener diodes back-to-back as shown on the attached drawing ..
Use a resistor to protect Zeners ..
IanP
:D
    Shreehari
is its so simple!!! here 0 V means ground right?
Yes, the 0v here means ground.
Hope this helps.
Tahmid.
    Shreehari
