How to put a bmp on an lcd
Dark Angel
Junior Member level 3
fastlcd
I begin programming in C a graphic LCD 128x64.
I found some programs called bmp2lcd wich change a bmp file into an array, but there is no example of using it.
How do you put this on an graphic lcd.
Does anybody have examples?
Thanks
I'v googled, but only found the programs and NONE of them explained how to use it.
bitmap to lcd
Already found this site.
Thanks anyway.
I use a program bmp2lcd wich makes header file from the bitmap wich you include in the c file. The header file contains an array, but i really don't know what to do with it. (i'm not an expert in embedded c).
On mp3 players with graphic displays are for example the buttons defined, but i don't know how this is done.
lcd bitmap converter
Which type of compiler and microcontroller that you program?
bmp lcd
At this moment i'm using an atmel 8515 with avr-gcc compiler.
After testing/learning i want to use it with a HC12.
But any example is welcome. Most examples in the net are for the character displays.
lcd bitmap
**broken link removed** has some AVR GCC code for graphic LCDs based on HD61202 or KS0108. You can usa that as the base of your project.
As for what do do with the header you get.
Enable left controller
Set Page and column address 0 . Sent 64 bytes from the file.
Do all of the above 7 more times, increasing the page address every time. Now you have your image on the display.
I hope this helps.
bmptolcd
Toshiba T6963C Dot Matrix LCD Controller example codes in PIC and Intel 8051.
bitmap lcd
Program to control a T6963C-based 240x64 pixel LCD display
using the PC's Parallel Port (LPT1:) in bidirectional mode
written in Microsoft Quick C
graphic lcd bitmap generator
graphic lcd bitmap
Go to
http://www.ucos-ii.com/
and have a look at uC/GUI, they are a lot of well structured C writen libraries, they can write on an LCD letters, numbers with different fonts and also bitmaps.
A.
lcd bmp
Thanks for the help.
The files from **broken link removed** really helped me out togeter with the instructions from Direnc.
For now the bmp is working on the total display.
Next thing to learn is how to put a small bitmap on a position on the lcd.
Thanks for the links and help from everybody.
bitmap converter lcd
Here's an AVR Graphic LCD example written with ImageCraft ICC Compiler: **broken link removed**
Main page: www.microsyl.com
bitmap to glcd
TURN HTE BMP TO DAT THAT the lcd can print on! it is 8bit data!see the lcd documentS and Settings!
fastlcd
HI ALL,CAN YOU HELP ME?I HAVE A GLCD 64X128 WITH LABEL SC12864J4 , BUT I DIDN'T SEARCH THE DATASHEET OF IT .WHO HAVE SEND ME PLEASE THANH
lcd bmp converter
Turn off your caps is shoooooooooouting ,
This post is 4.5yrs old :!::!::!:.
To place bmp on glcd either write your own code basic/c/asm etc etc or find bmp converter.
bitmap graphic lcd
hi iam using lcd JHD24064 with controller T6963c
iam want to display a bmp on lcd
pls help
