Power MOSFET driver ICs are made for this.
Just use a transistor with it's collector connected to the 10 volt rail via a resistor.
This will invert the pwm, if thats a problem, use two transistors, an npn and a pnp.
This is obviously the easiest way and I made it already. But my boss doesn't like it, cuz it induces about 40mv voltage ripple at the switch on/off edges.
So actually, I'm asking a "NO-switch" way... Thx anyway...
I'm not clear on that, you mean a way that doesn't involve any transistor or mosfet switch?
I was about to propose something like https://www.farnell.com/datasheets/85603.pdf but you are obviously searching for something else (non switch) but I'm not sure what it could be.
Alex
Assuming you are using a 3V3 Micro, these chips normally have an open collector output pin?
Feed your pwm output into an unused input pin, then translate those levels to your open collector pin, which you have pulled up to 10 Volts.
Job Done!
Job Done!
