How to Provide delay in Bit Sequence in MATLAB?
amitdegada
Member level 2
Surat, India.
Hello!
Can anybody answer me how can i provide delay of 260 ns in received signal?
The signal is received by passing tharough channel of 20 tap. Its complex valued signal!
It is easy to just use a timer in your code to hold and release or sent message to receiver.
    amitdegada
Hello Roshn!
I have read the help, but still not able to get it.
data=[1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1];
data=(data*(-2)+1);
%The K parameter determines how many bits are in one frame:
%num_bits_per_slot=10*2^K.
%The spreading factor SF is related to K as: SF=512/2^K.
%Select spreading factor=256 so K=1 hence there will be 20 data bits/slot
%So datarate=30kbps (k==>1 20 bits/slot*15 slot/frame=300 bits/frame and
%frame period is 10 ms.
%let's select OVSF code of length 4 for maximum data rate.
SF=4;
%Generate OVSF code.
OVSF_code=OVSFC(SF,1);
OVSF_code=OVSF_code*(-2)+1;
%plot(OVSF_code);
unsprd=[];
for i=1:15
unsprd=[unsprd data];
end
%split the data to I and Q, then Spread, conjugate the Q branch. and then
%add
I_brnch=[];
Q_brnch=[];
for i=1:2:300
I_brnch=[I_brnch, unsprd(i)];
Q_brnch=[Q_brnch, unsprd(i+1)];
end
%SF=256 ==>num_chips=20*15*256=76800chips/slot
%Spread the data;
Real=[];
Imag=[];
complex_baseband_signal_Pilot = 0;
for n=(1:length(I_brnch))
Real=[OVSF_code.*I_brnch(n)];
Imag=[OVSF_code.*Q_brnch(n)];
% complex baseband signal
complex_baseband_signal(SF*(n-1)+1:SF*n) = complex(Real,Imag);
end
%Complex Scrampbling.
[C1n_gold, SC_code]=scrambling(600, 500);
Data_scrambled=complex_baseband_signal.*SC_code;
% thermal noise generation with RMS noise_factor
thermal_noise = randn(1,length(Data_scrambled))*noise_factor + randn(1,length(Data_scrambled))*noise_factor*j;
% complex baseband signal is input into the estimated channel impulse response (hh)
channel_output = conv(Data_scrambled, hh);
% noise added to the channel_output
y = channel_output(1:length(complex_baseband_signal)) + thermal_noise;
I want to generate Delay in the signal Y
can u help me?
Okay, I will try.
Firstly why do you want to generate the delay? And do you want a delay of exactly 260ns? why?
In WCDMA RAKE RECEIVER the each finger is synchronised with single multipath having delay of one chip interval. That delay is 260 ns. That's why.....................
Please try
simply add zeros in front, accordingly to sampling time............
I think there is a program for delay in the book "Simulation & Software radio" by Ramjee Prasad. You can download the book from 4shared.com or gigapedia.com
adding zeros according to sampling time will certainly work and would be the easiest solution.
