zape said:A possible solution, only valid if you produce a low number of units, is based on the use of DS2401 (a Silicon Serial Number from Dallas). Your FPGA shall read this device and check for a valid number (so you will need one configuration bitstream per FPGA).
A Xilinx application note is attached.
