Dec 19, 2007 #1 M manish12 Advanced Member level 3 Joined Nov 21, 2006 Messages 983 Helped 66 Reputation 132 Reaction score 33 Trophy points 1,308 Activity points 6,117 16f716 i (multi prog )have it but the ic-prog software dont show the device list it pop down list. can any confirm that using same programmer with diff programming software , PIC16F716 be programme. thank you. or any other small option so that i can programed it
Dec 19, 2007 #2 ravimarcus Full Member level 4 Joined May 9, 2005 Messages 218 Helped 31 Reputation 62 Reaction score 12 Trophy points 1,298 Location Bangalore, INDIA Activity points 2,797 pic16f716 programmer manish12 said: i (multi prog )have it but the ic-prog software dont show the device list it pop down list. can any confirm that using same programmer with diff programming software , PIC16F716 be programme. or any other small option so that i can programed it Click to expand... Use https://www.winpic800.com. This supports 16F716. Cheers Ravi
Dec 19, 2007 #3 M manish12 Advanced Member level 3 Joined Nov 21, 2006 Messages 983 Helped 66 Reputation 132 Reaction score 33 Trophy points 1,308 Activity points 6,117 microchip pic programmer 16f716 thanx again sir. but the link is not opening ok it is opening
Dec 19, 2007 #4 ravimarcus Full Member level 4 Joined May 9, 2005 Messages 218 Helped 31 Reputation 62 Reaction score 12 Trophy points 1,298 Location Bangalore, INDIA Activity points 2,797 icprog pic16f716 manish12 said: thanx again sir. but the link is not opening Click to expand... https://www.winpic800.com/ I just check it and if you still have problem, let me know and I will email you the software. Cheers Ravi
Dec 19, 2007 #5 M manish12 Advanced Member level 3 Joined Nov 21, 2006 Messages 983 Helped 66 Reputation 132 Reaction score 33 Trophy points 1,308 Activity points 6,117 pic 16f716 thank you sir , i get the software but , will it work on programmer . oh no i misplace the chip ..............it required some time to check i will ack to this msg after successfully verify ... ok thanx
Dec 19, 2007 #6 ravimarcus Full Member level 4 Joined May 9, 2005 Messages 218 Helped 31 Reputation 62 Reaction score 12 Trophy points 1,298 Location Bangalore, INDIA Activity points 2,797 multiprog icd2 manish12 said: i get the software but , will it work on programmer . Click to expand... Winpic800 is better than ICPROG in many ways. Cheers Ravi
Dec 19, 2007 #7 M manish12 Advanced Member level 3 Joined Nov 21, 2006 Messages 983 Helped 66 Reputation 132 Reaction score 33 Trophy points 1,308 Activity points 6,117 icprog 16f716 not succeed using , picburner and multi-prog progammer.
Dec 19, 2007 #8 ravimarcus Full Member level 4 Joined May 9, 2005 Messages 218 Helped 31 Reputation 62 Reaction score 12 Trophy points 1,298 Location Bangalore, INDIA Activity points 2,797 multiprog pic manish12 said: not succeed using , picburner and multi-prog progammer. Click to expand... If your programmer is serial, then select JDM programmer. You can configure the I/O lines if you have any other programmer. Many have used winpic800 successfully. You must be making some mistake. Cheers Ravi
Dec 19, 2007 #9 M manish12 Advanced Member level 3 Joined Nov 21, 2006 Messages 983 Helped 66 Reputation 132 Reaction score 33 Trophy points 1,308 Activity points 6,117 multiprog ok , i will check it, but the device id is ok !
Dec 19, 2007 #10 S snorazizul Junior Member level 1 Joined Nov 22, 2007 Messages 17 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,360 pic programming software multiprog maybe u should give more detail what type programmer u use? Did you use Laptop or PC to program? How u connect to programmer?
Dec 19, 2007 #11 M manish12 Advanced Member level 3 Joined Nov 21, 2006 Messages 983 Helped 66 Reputation 132 Reaction score 33 Trophy points 1,308 Activity points 6,117 pic 16f716 rfid desktop pc jmd programmer self powered (without power supply) in serial port
Dec 20, 2007 #12 M manish12 Advanced Member level 3 Joined Nov 21, 2006 Messages 983 Helped 66 Reputation 132 Reaction score 33 Trophy points 1,308 Activity points 6,117 picprog pic16f716 yes i done it. for programming the PIC16F716 for my old pic programer from notch side jumper 1-2-3 for erase/read short the jumper 1-2 for program short the jumper 2-3
Dec 20, 2007 #13 M mImoto Full Member level 4 Joined Feb 21, 2002 Messages 210 Helped 4 Reputation 8 Reaction score 1 Trophy points 1,298 Activity points 1,733 16f 716 picmanual ICD2
