how to program rfPIC12F675
sshankar
Newbie level 1
rfpic12f675
i am interested in knowing how to go abt programming rfPIC12F675 using Mplab ICD2 .
programming rfpic12f675
rFPIC will be program as any 12f family.
CD
program rfpic12f675
Use PICKit programmer ...... but if you need use ICD2 pay attention on connections because it is much confuse in documentation of ICD2. Microchip has a connection document more easy of understand in your homepage
leomecma
rfpic12f675 program
Hi
You can use Tait, ProPIC2, JDM and WinPIC800 software, rf PICs can be programmed the same way as ordinary PICs.
Good luck
use rfpic12f675
hi
have u got answer how to program rfpic12f675?
i am also facing same problem. so if u have done program of rfpic12f675 than please inform me.
rfpic12f675 how to program
pls anyone can provide me a link to download any ide for programming rfPIC12F675...
its urgent pls
programming the rfpic12f675
Hi
The chips which come with internal oscillator required a simple trick to make them working first read them as blank chip note the calibration value of oscillator now load the program and you will see calibration value omit from the load memory
Now used option load calibration value in programmer and enter value which you noted during blank read write them in box just after 28, the attach picture self explanatory for all this procedure
Regards
Fragrance
