How to program 80C166-Board with a new flash memory?
samersalah
Junior Member level 2
80C166-Board
Hi ,
Do anyone know anything about this board ( 80C166-Board "UK/SD-9406001" ), it seems to be assembled long time ago ( about 1998 ) , it contains a SAB80C166 controller , an external Toshipa RAM , ST TKRAM , a flash 28F102 , and some logic 74xxx . Intially we used a software named FLASHMON to program it , but due to some problems with the old flash we had to replace it with a new one from ST 29F102 , the problem now is that the old programming tool won't program the new flash , do anyone suggest a timeffective solution, also if anyone has got any info about that board please post here ,
Thanks.
Re: 80C166-Board
Hi, have you tried MiniMon? Search the WEB!
By WDM
Re: 80C166-Board
OfCourse , i have downloaded and tried MiniMon but it seems that SAB80C166 is not supported ,
it recieves MC-identifier correctly , it then says LoaderACK 01 recieved ,
then ERROR : no MiniMON XC16x byte recieved
Re: 80C166-Board
Hi, sorry for stupid question, but sometimes ... you know, .... did you make a FLASH-driver for 28F102?
WDM
