how to process mif file in modelsim
zhuoyue
Newbie level 6
modelsim mif
now ,i use altera device block ram as a rom,my init data in mif file ,
but now ,if want to simulate the design in modelsim,how to process mif file, what should i do?
thank a lots
zhuoyue
bigrice911
Member level 3
modelsim mif files
MIF file is something like text file with its own data format, you can treat it like text file IO.
visualart
Advanced Member level 1
.mif modelsim
u may compile the sram with the quartus or maxplusII. In the procedure of the compile , u may indicate the file mif.
zhuoyue
Newbie level 6
mif modelsim
Solution
The ModelSim tool does not support the memory initialization file (.mif) format and requires you to generate a .hex file as specified in 1430.html. Once you have the initial memory contents specified in the .hex format, please note the following:
If you are simulating in a VHDL environment, the ModelSim tool will automatically reference the .hex file you have created and no additional steps are required.
If you are simulating in a Verilog environment, the ModelSim tool requires an additional .dll file that is included with the Quartus II software. To use this .dll file, please take the following steps:
Open the modelsim.ini file (Make sure to open the copy that the ModelSim tool is currently using. If you have a modelsim.ini in your project directory, that file will be used.)
Search for the following lines:
; List of dynamically loaded objects for Verilog PLI applications
; Veriuser = veriuser.sl
Remove the semicolon (;) from the "Veriuser" line and point to the location of the .dll file as follows:
Veriuser = \eda\mentor\modelsim\convert_hex2ver.dll
Save the changes, close the. INI file and re-start the ModelSim tool.
Note: if you are unable to save the changes, please make sure to change the permissions on the modelsim.ini file from the Properties menu.
zhuoyue
Newbie level 6
modelsim mif file
you can complie the source(it includes block ram),when output *.vo file ,you can simulater the vo file without sdf file in modelsim,it can work!
freeinthewind
.mif to .hex
to zhuoyue:
Solution
"The ModelSim tool does not support the memory initialization file (.mif) format and requires you to generate a .hex file as specified in 1430.html. Once you have the initial memory contents specified in the .hex format, please note the following:"
how can i generate this .hex file from .mif file?
forklifttruck
Newbie level 3
To turn a .mif into .hex just open the .mif in Quartus II, then save the file as a .hex and Quartus II will do the conversion.
