How to print 0 (zero) in ASCII using Verilog?
research_vlsi
Full Member level 1
Hi friends
am unable to convert "0" to ASCII in verilog HDL, however in ascii first 32 characters are non printing char..
so anyone knows how to print 0 (zero) in ASCII using verilog.
whether its possible to print?
ASCII in verilog
What kind of variable contains the "0"?
Show us your code to clarify exactly what you are trying to do.
ASCII in verilog
that sounds a virtual trouble!!!
Point is
1. Clarify where the'0' is and where u want to print it
2. All u need typically is add 30h or 48d when sending for print or display
and subtract the same when sending input ascii to be processed
