Register Log in
How to Plot Vth Vs L for RF input
shaikss
Full Member level 4
Hi Folks,
I have to plot Vth Vs L, Vth Vs W for my rectifier 4-T cell structure.
I am giving RF input.
How to plot Vth Vs L or W?
Thanks!
erikl
Super Moderator
Staff member
Germany
Vth doesn't change very much, neither with L nor with W.
For a plot run a DC analysis and sweep L resp. W.
shaikss
Full Member level 4
I am giving ac input and so i can't use dc analysis.
shaikss
Full Member level 4
... and so you can't get your plot :roll:
But I need Vth Vs W/L for analysis. I want to lower Vth by doing some biasing.
Not getting...how to do...confused:???:
erikl
Super Moderator
Staff member
Germany
Then follow my suggestion above! Vth dependency on W/L (if any) doesn't care about an ac input signal.
You can lower Vth (a little bit) by some forward biasing of the bulk -- if this is possible.
shaikss
Full Member level 4
erikl,
My designed rectifier is for low power application....that is, rectifier has to provide dc voltage for min 150mV.
In order to serve this purpose, I want to lower Vth, a little.
I thought of providing some dc bias to the gate of the mosfet. But again, I don't want to use external supply voltage because of some constraints.
I have attached my schematic.
Pls let me know what can be done in order to lower Vth without use of any external dc supply voltages.
Thanks in advance erikl
steadymind
Full Member level 4
USA
Vth variation with W/L is based on your DC operating point. You can plot that using a parametric sweep. As for reducing Vth, you need to try biasing your bulk, or use natives. Its a trade-off.
Toggle Sidebar
