How to plot the base current of BJT after running PSS simulation in Spectre?
bouchy
USA
How can i plot the base current of bjt after runing PSS simulation. Also using the PSS how can i plot the time domain waveform of output voltage and current.
thanks
bouchy
p.mlo
Junior Member level 2
Poland
Re: Spectre questions
PSS - PS Spice ?
For a time domain plot there is a Transient analize, on circuit there must be voltage and current market.
For base use param command (param r) and type r of a resistor resistance as variable param.
You will get many lines in transient analisis.
    bouchy
armixic
Member level 1
U.S.A
PSS - Periodic Small Signal
In the plot sub window, there is a time domain waveform option. choose it and draw a time domain waveform.
    bouchy
