How to plot co- and cross polar radiation pattern at E and H planes in CST ?
Sarah.Mokbel
Newbie level 2
Dear All
i have a project on a IEEE article " Integrated bluetooth and UWB Antenna "
and i have several questions
1. I don't know how to plot the co and cross polar radiation pattern at E and H planes in CST at given frequencies (fig.4)
2. how to plot the gain & directivity vs frequency (fig. 5)
I appreciate your quick reply with detailed steps as I am not so familiar with CST
thanks in advance
EMC_simulator
Junior Member level 1
Germany
You can make both plots with the template based postprocessing. First of all you have to set farfield monitors at the wanted frequencys. You find it unter "Solve" --> "Filed Monitors". Then Choose "Results" --> "template based postprocessing". There you have to choose Farfield results. In the upcoming window you can selevt whatever you need.
Sarah.Mokbel
Newbie level 2
thanks for ur effort , could u also tell me how on HFSS
nf707
Member level 1
iran
Hello in hfss(ver 10)
results create reports {█(far field@radiation pattern)┤
then click ok
you first chose soulution (create reports)---(far field-radiation patterns) then click ok, you first choose solution (sweep for all frequency) then
in sweeps tab chose a frequency (one frequency) chose phi=0 or 90 and your primary sweep must be theta
in mag tab choose rE (category tab) and in quantity select rEphi and rEtheta( dB)
if don’t solve your problem up your file
